This summer, I finally tackled replacement of the rotted core around the mast on my O'Day 32' center cockpit. The POs were elderly, and there had been leakage around the mast, as well as a hatch coaming that had rotted. I rebuilt the coaming out of blue styrofoam a few years back, then put about about 6 ply of glass cloth, and epoxied it thoroughly. I has not leaked since. To do the coach roof around the mast, I used a moisture meter, and found the edges of the core rot. I cut off the top skin with a Fein saw, and removed the wet and rotted core. I replaced the balsa with 1/4" inch mariine ply thoroughly coated with epoxy. I then bedded the marine ply thoroughly with epoxy, then put the top layer of glass back on and bedded it thoroughly with epoxy. I did not do kerf cuts in the ply because the deck there was pretty flat. I used brass flathead screws to help conform the "sandwich"to the slight curve around the mast. I sanded the deck to get it smooth and faired and then covered the repair with antiskid. Now I see the seams of the repair. I'm planning to grind out the offending seams with a Dremel and epoxy the grooves. Any advice?
