Wisker pole
Apr 23, 2012
69
Hunter 430 Kemah
430 Hunter, was going to install a 13/22 wisker pole on mast track, but informed was to heavy, was not recommended for this boat,as per the chart that is used, was recommended the tri-reacher unit. One concern was informed that the mast would have to come down to install track, or is there a track that can be installed from outside.My question is since the tri reacher is less than 20lbs ,can I use the fix mast swivel instead, and mount the unit on the stanchions. I will only be running the 110% jib. No intention of running anything else. Opinions and thoughts appreciated.
1,966
Endeavour 42 Cruisin
why not install track while the mast is up? I had mine done that way 2 years ago, for the largest Velocity pole Forespar makes; for my 42' boat. mast mount is awesome.
Apr 23, 2012
69
Hunter 430 Kemah
Do you have a 5/8 wide groove ran down the center of your mast,mine is about 1/8 deep.If so what track did you use?
Dec 25, 2000
5,739
