I need to replace the wiring from the stern to the mast base where there is a connector for the mast. The wire on the top of the cabin is brittle and I need to replace it or extract 3 inches to attach the connector. Can anyone give me a suggestion to loosen the wire from the cabin top, it seems to be glued in place? I have drilled around the hole and it remains intact.
