I will soon be installing a Raymarine 2KW scanner on my newly acquired 1983 Cat 30, and was wondering if there is a satisfactory method of doing so WITHOUT unstepping the mast. I will be mounting a Seaview platform somewhere around the speaders (depending on the exact location of existing lights etc.). It has been suggested that using the halyards (internal to the mast) to pull a "fish" line to the top from the bottom, and pulling the radar cable up from the bottom might work. Also I intend to install a juntion box in the cabin ceiling, where I will disconnect the cable within the cabin, for future disconnections. As an interim measure, I might also simply surface mount the cable for the upcoming season, and unstep the mast in the fall to complete the permanent installation with the mast down. The latter approach will complicate placement of the cable hole in the deck. Any suggestions will be appreciated.
