L
Larry Connolly
I have a pull switch on the Yanmar instrument panel. At first I thought it might be an engine stop cable. On closer inspection the switch is wired to a 12 volt feed that is part of the original harness. The wire is labeled LASW, there seems to be nothing currently hooked to it as having it on/off makes no difference. I'm wondering if anyone else has a similar switch.ThanksLarry
