Tony
I'm going to install a 12V receptacle next to the power panel on my 240. I took the panel out last night to check out the wiring before I cut a hole for the receptacle. I can't figure out where the negative wire (usually black) is attached to the power panel. The positive is very easy to spot. It attaches to the lower fuse and all the positive fuse terminals are wired in parallel. No sign of the negative though. Can anyone out there who has done some wiring on the 240 help me out?
