wiring from mast
G
Gary
I will be taking my mast down next weekend for the first time since I purchased 2 years ago. I have a traditional layout tall mast rig. I understand that the wires run through the mast and there should be a connection I should see once I raise the mast. My question is where do the wires run once they go through the deck? To my knowledge there have been no modifications to the wiring system. Where can I get an original wiring schematic. I have tried Catalina but never recieve a response. Thanks for all help
Jack
fax
If you post a fax #, I will send the schematic that I have. We also have a 1986 27. Jack
Sonny Ferrell
same question 1978 C27
I have the same question for a 1978 C27. Is there a chase that I can use to run additional wires without thru-deck fittings?
