You can fish...
...it through. If you use the old wire/covering as a lead and attach the new wire to it (end to end) well, you can probably fish it all the way like that. But, if I'm involved things will go wrong, so it'll get a little dicier. The wires from the mast (anchor light, steaming light and antenna cable) go between the cabin top and inside liner, about where the bulkhead is, then aft along the port edge of the liner. If you peel back some of the fabric hull liner, you can reach your hand up into the edge of the head-liner in the cabin and feel the wires. There is a recess where the wire bundle rests. There is likely enough slack in the wiring harness at the panel end that you can pull the wiring bundle up a small bit to make room/clip the cable-ties/fit a new wire.
