Anyone have a diagram & wiring schematic showing how to install a macerator pump? Appreciate any advice and/or sketch.
Thanks
Not any detailed advicey, but general concepts
1. the motor should be wired in parallel.
2. the amps of the circuit should not exceed the fuse that protects the circuit
3. the total voltage drop should not exceed the voltage that the motor requires
4. If none of the above makes sense, DO NOT DESPAIR....buy don casey's "basic Sailboat electrics". it is all pretty simple, and fun to do once you get the basic idea.
i had to rewire my boat, and once i reviewed the above, rather small book, i had it down pat.
keith
