I have a 17' Vagabond Day sailor, There is no power on the boat currently. I want to wire an old car stereo (Alpine CDE 7870 45watt max) to a marine battery. I would also like to rig running lights.I have several questions about this procedure:-What type of battery to get? I want to be able to run the stereo with 2 speakers for about 15 hours without recharge. Some people say a Deep Cell, some say a Starting battery, which one? And I'm guessing at least 650 CCAs- I have a 5hp Mercury Sail Power outboard with the option for a 56 watt battery charging Alternator kit. What battery would best be compatible and what wiring method would be most appropriate when I get this upgrade in the future?- I am also assuming that I would run the ground back to the battery...- Are fuses necessary for this? If so how would they fit into the circuit?- What type of AC trickle charger do you recommend for the battery?If anyone has any tips, hints, or pictures, I would greatly appreciate it. Thanks
