In the process of installing new batteries on Still Crazy this weekend, I encountered several curious problems. As I connected the final negative ground across the battery banks, I saw a spark as the lug touched the terminal. Problem was that the battery selector switch (1, 2, Both, Off) was set to OFF and the battery was otherwise not connected to anything (including the sump pump or the battery charger). I checked the selector switch and in the OFF position there was no continuity between the common terminal and terminals 1 and 2. I disconnected the batteries entirely and as I investigated further I found that four circuits (cabin lights, macerator, steaming light, and running lights) showed continuity from the positive bus to the terminals on the other side of their breakers even though the breakers were in the OFF position! In addition, when I disconnected these four terminals from their breakers, each one showed continuity with each other! Could all 4 be shorted out shorted out together somewhere? I was using a simple bulb type continuity tester. I had recently installed a fan in the V birth on the cabin lights circuit so I disconnected it to see what would happen. I still detected continuity across the 4 closed breakers but perhaps the light was not quite as bright. Finally, I reconnected one battery, again with the selector switch on OFF. Again I saw a definite spark as I connected the negative terminal but it was much fainter. I inserted my multimeter between the battery terminal and the ground (negative) lug and it read only 0.01 milliamps; then same as when it is connected to nothing. Not only can’t I figure out what is going on, I can’t even think of what to test next. All my buddies at the dock are also stumped. Any thought would be greatly appreciated.
