What don’t work?
Hey Jim, you do have good taste in sailing boats! So, what don’t work?For the most part, the older boats like ours have had the wiring fiddled with so many times, there’s little original stuff left. You can get the owner’s manual from Catalina Direct, (http://www.catalinadirect.com/index.cfm) just keep in mind, your boat has most likely had a lot of gear changed out, usually by duffers like us.A great source is Catalina 27 Association http://www.catalina27.org/ they have sections of manuals as well as experienced members.This guy has stuff on his site dealing with battery wiring and the like. http://www.ariasails.com/ray.htmlThese people also have a very good page on resurrecting Catalinas. http://www.blumhorst.com/catalina27/catalinahomepage.htmActually, if you start at the fuse & switch box, it’s fairly easy to replace or upgrade wiring one item at a time. Mostly, you’ll find your problems are more at either end as opposed to actual wiring.Later, eh!Ferg
