With winter fast approaching, I'm getting ready to haul-out and need some help with winterizing the engine. I have a Volvo 2020 w/saildrive w/fresh water cooling. The boat will be stored and engine winterized on land. 2 questions .. (1) Do I need to drain seawater from the system before before starting the engine and drawing anti-freeze (pink stuff) through the sea water intake. Or can I just start the engine and run until I see pink stuff coming out the exhaust. If I need to drain, how do I do this?(2) When I've had the engine winterized in previous years, they have poured antifreeze into the water strainer as the engine is running until we see it coming out the exhaust vs. removing the hose from the sea water intake. I suspect removing the hose will be a struggle and don't want to run the risk of a leak here in future. What do you recommend?
