The primary cause of death of raw water impellers--and the reason for the advise--is pink polypropylene glycol. The impeller is neoprene (check the brand) and neoprene is not comparable with PG (Google neoprene chemical compatibility--many sources). It gets hard and the vanes break off. The solution is to use automotive AF (ethylene glycol), which is compatible with neoprene (one of the reasons it is preferred in cars is better plastics and rubber compatibility).
Why do we use PG around boats?
a. Lower toxicity in potable water systems. It is the only safe choice (some use alcohol, but that has its own problems and is false economy).
b. The mistaken idea that PG is better for the environment. In fact, there is no difference. Just as zinc is lethal to fish but not humans, EG is lethal to humans but effectively harmless (EPA's own words) to marine life.
c. Biodegradability is equal. If they say different, ask for data. The EPA says they are equal in biodegradability.
So use auto AF on the engine (black water system too) and the impeller will last longer. I've done side-by-side testing for a research project. I generally get ~ 5 years and ~500 hours before I change them, and them it is only caution. Failure is closer to 1000 hours.
