not able to start motor to winterize. Is there a way to drain raw water from yanmar ysm12 to keep block from freezing?
Can't understand why you can't start the engine? Can you elaborate?not able to start motor to winterize. Is there a way to drain raw water from yanmar ysm12 to keep block from freezing?
How would you make sure you don't pump antifreeze into a cylinder? With the engine running, the exhaust pushes everything the right way... Isn't that engine raw water cooled? No heat exchanger?Maybe it won't start. You should be able to pump anti-freeze through the system with an external pump - drain everything you can first to make it easier.
Generally not a good idea. Suffice it to say engines aren’t designed to resist positive pressure of an external pump. If you want a further explanation, ask.Maybe it won't start. You should be able to pump anti-freeze through the system with an external pump - drain everything you can first to make it easier.
thanks Peggie for the info!You'll find complete instructions for winterizing both the fresh water system-- with or without antifreeze-- and the sanitation system in the Plumbing and Sanitation forum.
--Peggie
thanks for the links to winterizing boat engines, was not aware that there was different types of R/V and marine anti-freezeCheck the forums for winterizing your engine and boat. There has been volumes of how to helpful ideas over the years.
Here are two link’s that may help you with the tasks.
Engine Winter Freeze Protection - Marine How To
This Came Out of a Boat Stored Winters in Maine I got a call from a customer who felt his motor was running a little hot in the fall and thought he should address it during the off season. We decided to pop the caps off the heat exchanger,marinehowto.com
Freshwater System Winterizing - Marine How To
What Not To Use For winterizing your fresh water system you will need a few items. The number one item to have is RV type propylene glycol antifreeze that is safe for domestic plumbing systems. Unfortunately, I see this type of alcohol based RV type product all too often.marinehowto.com
