I always fill er up
I fill the tank and add stabil as formula on bottle. On my 85C30 I also winterize the engine & exhaust by removing the hose clamp on the thru hull for fresh water pick up, then stick the hose in a bottle of anti-freeze, the water pump will pick it up and suck the bottle dry, I use 2 gallons, just switch the hose real quick or pour both in a bucket. When they are empty shut off engine as soon as they are empty, need someone at the controls and someone at the engine. This will keep everything ready for spring. Remember in the spring when you fire it up it will pump out all that antifreeze into the yard or whereever. I have a garden hose juryrigged to connect the that same water pick up so I can run the diesel all I want, right in my yard. Good luck.Dean www.blowinganddrifting@yahoo.com
