I'm not familiar with the Honda OB
but when I winterize my Evinrude 8hp I do it by first running the engine in a barrel of fresh water to flush out salts and other materials. With the engine running at about 1500 rpms, I squirt the fogger oil into the air intake. Big billow of smoke, then shut the engine down. I then removed the plugs, cleaned and gapped them, sprayed the fogger into the cylinders. Replaced the plugs. YOu may able to squirt some fogger into the air intake on your engine, remove the plug wires, and pull the start cord manually to move the fogging oil around the cylinders. At some point, you'll have to deal with getting that frozen plug out. You could try to gently tap the metal base with a hammer and screw driver to loosen it up, or apply some heat (very carefully!) with a torch. Use a perfectly fitting socket on the biggest socket wrench you can find, or add a piece of pipe to the wrench handle to gain leverage and apply brute force. Next time, apply some "Never Seize" or similar product to the threads of the plugs when installing them. Good luck with this.
