New-to-us 2008 Hunter 36. With the goal of winterizing the house water system, drained the tank at the bow, drained the hot water tank. Put 5 gallons of pink stuff in the fresh tank. turned on the water pressure pump. Toilet, check, most but not all cold lines, check. Hot lines, not so much. Did I just fill the hot water heater with pink stuff? nothing at all comes out of the stern shower, pressure pump just runs. Do I just need more, or did I do something wrong. Boat is new to us, still have a bunch of stuff to figure out.
Ok, here is what I do, and why
Drain all the tanks until empty
Go to the tank manifold, and shut each one into the pump feed sequentiality. If you just run the pump until it’s sucking air, you could still have water in one tank
Install hot water bypass tube
Open drain on hw tank, and leave it open all winter.
Disconnect input to fresh water pump
Connect a pail with hose at the bottom which has a whale fitting on it to connect to pump input
Fill pail halfway with pink antifreeze
Turn on water pump, and then go around boat turning on each faucet until pink runs out of them.
Because you installed the hw tank bypass link, this will winterize both your hot & cold faucets
For air conditioning, do the following
Disconnect hose from output of strainer. (Shut off through hull)
Then, connect your pail hose to the hose you just removed (will require a minor adapter)
Fill pail with pink, and turn on airco
Watch the side of the boat for pink exiting the airco though hulls.
By running the antifreeze directly into the fw pump, you have no issues in the spring with clean lines, and no taste problems
I tried variations of air compressor, vaccuum, etc., over the years. I always had problems that water in “low spots” wouldn’t evacuate, and had damaged fittings, etc.
