What I do...
You didn't say if you're talking about leaving it in the water or taking it out. I don't know where Janesville is so I can't guess.If you leave it in the water, there have been many discussions here about that. I think the usual advice is to not take the chance if you have freezing weather and pull the boat out of the water. That's what I do, but I live in Canada.I've stored mine for two winters now and I just do what the H23.5 manual says: - open the ballast value- put the boat on the trailer- pull it up the ramp a few feet- watch the water drain out- park the boat and trailer for the winter, leaving the ballast valve _open_- pout and sulk and cry for 8 months of winter where temperatures can reach almost 40 degrees below zero.-40 is the same in celcius and fahrenheit, so take your pick!Seriously, the only trick is to leave the value open as the manual says.Don't forget to empty the water tank that feeds the sink.I put the battery and outboard in my unheated garage after following the engine draining instructions in the outboard's manual....RickM...
