I don't have anything to add with regard to getting the hose off the inlet seacock, but that's been addressed pretty well.
To make the process easier on my Catalina 28, I have a bucket (kitty litter bucket) with a 90 degree barb fitting in the bottom at the edge of the bucket. I just drilled a hole in the bottom of the bucket about the size of the barb, stuck in the barb, and did a little sealing with 3m 4200. Then, I attach about a 3 foot hose to the bucket and connect the other end of the hose to the inlet hose with a barb/barb connection. I set the bucket down where it will be stable, and then put a couple gallons of antifreeze in it. Then I go up on deck and start the engine.
I used to just stuff a hose into a gallon of antifreeze, but there always seemed to be a lag between the time I started at the engine and the pump started moving the antifreeze. I don't like the idea of the impeller running dry while I try to get the vacuum started.
The bucket method guarantees the antifreeze will get picked up by the inlet hose quickly.
So, my winterization "kit" consists of the bucket (with barb), a 3' length of garden hose, and a barb/barb connector.
Easy and reliable.
Someone already mentioned about using plenty of antifreeze. That's right...at least according to MaineSail. He set me straight. Just watching for pink stuff to flow out the exhaust is NOT good enough. After you see solid pink, keep the engine running and run at least another gallon of antifreeze through the engine. MaineSail says because there's water in muffler and exhaust system, that first pink you're seeing is antifreeze mixed with water, and it takes a lot more antifreeze running through the system to reach a high enough level of antifreeze in the system.
