Winterizing A4
Sep 10, 2014
9
Ericson 29 Olcott, NY
The Ericson 29 we bought this summer has an Atomic 4 engine, with which I have no experience ( our previous boats had diesels or outboards.) I'm getting conflicting local advice about how to winterize the A4 engine after I get the boat up on the hard?
It is raw water cooled. Is there a consensus on the best method?
Thanks
Rick I
Jan 6, 2007
414
CS36Merlin and Beneteau 393 - Toronto
Never done a A4 but with raw water cooled engines you usually remove the thermostat, run anti-freeze through the engine and then replace the thermostat.
With an A4, have you been made aware of www.moyermarine.com?
THE place to go for A4s, everything you ever wanted to know and more.
Bookmark it, and live there for a while.
Good luck.
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
Go to the Moyer Marine website. Find the Atomic 4 service manual and buy it. The manual has the winterization procedure clearly outlined.
If you are getting conflicting local advice it is probably because your local advice is not so good. Many so called mechanics are not familiar enough with the A4 engine to winterize it.
Get the manual, do it yourself, and it will get done right.
