I finally realized how stupid it was to pump 6 gallons of anti freeze into the hot water tank and disconnected the feed and the out lines from the tank. Nothing came out when I disconnected as I had emptied the system by the running the faucets dry. On the hot water tank, the lower connection is water in and the upper connection is hot water out.
Anyways, I plugged up the IN line to the hot water tank and ran anti freeze through the rest of the system. Then I unplugged the inflow line and let anti freeze run through it as it emptied into the bilge.
There must be a small amount of water in the bottom of the round hot water tank, but I figure it will not hurt anything as it will expand like an ice cube tray.
Am I overlooking anything here?
