Pull Plugs
Paul, you can fog with an atomizing oil by pulling plug and inserting there, then turn the engine over by hand. Killing the engine by fogging through the carb is a good technique that we used to use with an air boat. Warren, I'm not sure which is best. Stabalizer is definitely good for a few months, but I wonder when one puts up the engine for a few years? The first OB I ever had was used and had a lot of "varnish" in the carb which we thought was from the gas evaporating and leaving behind the "varnish". Over the past 40 yrs in the arid West, have had no problem with the running dry approach, though it has always been with 2-cycle engines. Perhaps a 4-cycle is more toouchy as they wouldn't leave an oil surface over the inside of the carb. parts. Dick
