WINTERIZE YANMAR 1GM10
293
Alerion Express 28 Oneida Lake, NY
Nick Maggio, Seitzinger, Steve O and Bill Roosa... Thanks for your help!!! It was easier than I had anticipated, and as you described - just pulled the outlet hose off the bottom of the stainer, put it into the antifreeze bucket, fired up the engine (the only difficult part) and pumped it through the system. I wanted to fill with antifreeze instead of wintering dry as I had read that dry storage might rust some of the cast parts of the cooling system. Again, THANKS!!! Paul
Jun 2, 2004
257
- - long island,ny
1st time is the hardist
It can be tricky the first time but you do it you find out how easy it reall is.
