We're new owners headed into storage for the first time. We will be using a covered, unheated, three-sided shed without power access in the Pacific Northwest. All fabrics (except the hull liner)will be removed, with cupboard doors and storage panels opened. I have read a number of different approaches to controlling humidity. Is it best to leave ports open for maximum air flow? Are "Dry-Z-Air" type dehumidfiers appropriate? And if so, does leaving ports open merely draw outside moisture into the cabin to the dehumidifier? I also read about moth balls for mildew control. Are they appropiate? Thank you all in advance for your thoughts.
