Worthwest Stuff Turns Green
To store your rode for the winter, rode being line and chain, I'd recommend taking it apart and washing both sections in plain fresh water and let dry. The line will be harder to clean because of all the silt it's picked up. Washing it in the tub should do well as you don't need to get it as clean as bed sheets. If you put it in the washing machine it'll get all tangled and twisted. Don't use soap on the line because it will generate mildew easier and washing something in the washing machine, even though it is with plain water, will pick up residual soap.Let dry and, depending on the length of chain, you didn't say if you had 20 feet or 200 feet, store it in a plastic bucket with the lid off. Leave the shackle on the end link so you can spot it easier.Ditto the line. Find smething approprite for the size and weight. Then store both in a dry place.If you're going to be reuising the rode during the winter you might as well leave it on board as this is a lot of work. If it is left on board and not used it'll turn some shade of green by next spring.
