We bought a '78 Annapolis 26 last year mid-summer. She's a bit spartan and rough around the edges, but has a sound engine and lots of fun to sail. We took her out a few times last year and had a blast. Unfortunately, I was overseas for all of this season and am just now getting back to her. Upon cleaning her up this week, here's what my winter projects are:1. Replace all 4 wood bulkheads, mainly the two that the chainplates are attached to. They're not looking good at the bases, and previous owners covered rot with plastic edging. There's also pulling at the bolts, so I'm hesitant to take her out again until I get this done for fear of them failing. I also see evidence that the mast compression post may need some help. There's also a slight separation (1/4") in the fiberglass joint below the mast compression post between the deck and where the deck joins the settee side. I can reinforce it up from the bottom in the bilge, but it looks like it's been glassed over before and separating from age (i.e. mostly cosmetic, not structural). Can I use exterior grade (ABX) for replacing the bulkheads? Should I consider a coat of epoxy for them prior to installation? This seems like a fairly straightforward job once the mast is off.2. Figure out what is going on under the foredeck--it's bouncy. Tape-on non-skid was hiding several large holes (2" diameter) where it appears someone poured resin into the voids to firm it up. It's a sloppy job, and I'm anxious to cut and pull the entire cover back to see what's underneath. I know it's not going to be good, so I'm anticipating this one being the ugliest. Don Casey outlines the steps to fix this in "This Old Boat", but has anyone out there with just a basic knowledge of fiberglass ever done such a thing? Fair winds, and as always, thanks for any help!
