Any tips on pulling the mast on a 27-3? It appears that the spreaders are below the mid-point on the mast, I hate to have to go up in a chair and set the strap if I don't have to.
Second question is winterizing the fresh water, I have one of the safety mixing valves on the hot water tank. Normally I would drain the tank and connect the in and out hoses to bypass it for winterizing, I know have three hoses, two cold in, one hot out. The previous owner had the tank full of pink antifreeze with all lines still connected. No big deal, I can do that again but wondered if there was a better way?
