My, new to me, Passage 42 is on the hard for the winter. I would like to set up a generator to charge the batteries every month. The generator is a Briggs and Stratton 5500. The manual states with a 120/240 Volt AC, 30 Amp, Locking Receptacle. Use a NEMA L14-30 plug with this receptacle. Connect a 4-wire cord set rated for 250 Volt AC loads at 30 Amps (or greater). You can use the same 4-wire cord if you plan to run a 120 Volt load. This receptacle powers 120/240 Volt AC, 60 Hz, single phase loads requiring up to 5,500 watts of power (5.5 kW) at 22.9 Amps for 240 Volts or two independent 120 Volt loads at 22.9 Amps each. The outlet is protected by a two pole rocker switch circuit breaker.
I can get a NEMA L14-30P to L5-30R Power Cord, 30A/125V, 10/3 SJOOW adapter.
The question is can this work without blowing something up or any damage to the boat (I don't care about the generator) Thanks
