Actually, batteries have changed a lot
This even includes the chemistry. e.g. with regard to the composition of the lead plates. Most AGM batteries now have calcium or other inorganic additives in the lead plates that slow down self-discharge rates to as little as 1% per month. As a result, some fully charged AGM batteries can be stored for quite a few years before the charge levels would drop into the danger zone. Moreover, the lower the temperature, the slower the self-discharge process will go (unless the temperatures would be so low that freezing might cause dramatic phase shifts).I don't disagree with you that a battery left discharged for a long time will be damaged. But why try that? The idea is, of course, to first fully charge the battery and then disconnect any and all electric leads. Sometimes, it may even be necessary to clean the top of the battery from accumulated salt, etc. in order to achieve the lowest possible self-discharge rate. I have included a Google search link that will connect you to quite a few battery literature references on the net in order to back up my arguments.Have fun!Flying Dutchman
