Trickle Charge At The Very Least
Scott, most automotive chargers trickle charge at a steady 2 A. If your topping -up deep cycles of larger capacity, say 200A or more, leaving the charger on, may not overcharge the battery. If your battery is smaller than 200A that trickle charge may overcharge the battery if you forget to unplug it. A smart, 3 stage charger will take out the guess work and the human error. If your going to invest in a "on board" smart charger, (if you have 110V system onboard) wire it so that you can plug/unplug it from the boat. That way you can bring it home, along with the battery, and plug it in for the winter at home. The smart charger will self-regulate the charging current based on the condition of the battery. I have a guest 10A, 2 bank smart charger, and have it plugged into my 110V system on board. I have unplugged it and have it at home keeping the 2, 6V, 240 AH golf cart batts topped up over winter. At the very least, check the battery condition with a hydrometer or voltage meter. A charged battery will show above 12.5V, and a flat battery will be below 12V. There is a post in the "Ask All Sailors" forum you may want to read. Don
