What they said, but
As the current owner of a 235 wing keel (happily I might add), I see the biggest advantage in launch and retrieval from a ramp to a trailer. The fin keel will perform better, and in the case of the 235, make it only slightly less tender. But unless your doing some serious racing, this difference will be minimal.I like being able to pull into shallow water areas. We routinely anchor in 4-5 ft of calm water and walk ashore (warm weather permitting). The only trick to the wing keel on the 235 is that the rudder is deeper that the keel. This means that it will hit first, and the gundeons are not the strongest, which, if you hit has speed. could leave a serious hole in your transom just above the waterline.You also might have a tricker time getting off a sand bar or mud bottom when you do touch terra firma. The flat wing won't release very quickly and you don't lessen draft by heeling.My opinion? As a first time buyer, with the potential to sell in the future, go for the wing keel. You'll get to more out of the way places (on the water and highway), and you'll find more buyers when it's time to sell.
