Wing keel
1
CAL 33 Charlevoix, MI
I'm considering a new Catalina 400. There's one on its cradle wintering next to us that had a problem with the fairings of its wing keel and had to be worked. I was told by the marina operator that its a rare problem. But I'm wondering if this happens to the 400 frequently enough for me to reconsider. If there are any 400 owners out there that can assuage my feelings, I'd appreciate a response.
Dr. Marshall Cossman
swttooth33@yahoo.com
May 25, 2004
446
Catalina 400 mkII Harbor
i have had a 400 for a little over 2 years and still associate with the original owner. i can report no keel problems. you may want to ask your question on
http://groups.yahoo.com/group/Catalina400/
there are many knowledgeable owners of 400 that will provide quick response!.
great boat, good luck
mike
Keel fairings are subject to periodic repair. Like it or not keels swing, fiberglass deforms and fairings don't always deform the same amount. There's also groundings. It doesn't mean there's a structural flaw. A hard grounding, on a particular boat, as evidenced by fairing cracks or even fiberglass cracks (Look at the hull in front of the keel) is a subject of interest for your surveyor.
Sep 29, 2008
1,980
Catalina 310 #185 Quantico
Catalina Smile
Isn't that what they used to call the Catalina Smile on the old 30's? Never had that problem on my 310 FWIW.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
If you've got serious questions about the boat, I would recommend that you contact CRUISINGDAD on Sailnet's forums or anything-sailing.com. He is the technical editor for the Catalina Mainsheet newsletter on the Catalina 400 and owns one. He can probably address any issues or concerns you might have about the boat.
Hunter 25_73-83 NORTH POINT MARINA/WINTHROP HA IL
wing keel delamination
The problem is fairly common and is primarily caused by improper etching of the lead/iron before application of the fairing compound. To repair, remove the delaminated material, grind/feather the edges with 80 grit back to clean adhesion, re-etch the metal and refair the keel. I would recommend West System epoxy since many of the delaminmation problems I have personally experienced have occurred with Interlux fairing compound. Co-incidence? This would not prevent me from buying a good solid boat. It is not related to the wing keel Best, Rognvald
Bob S
Sep 27, 2007
1,813
Beneteau 393 New Bedford, MA
How do you etch the lead?
etching lead
Bob, Once the fairing compound has been removed and your down to clean lead, use a very stiff wire brush attachment on your drill or grinder to "scar" the surface of the keel to expose fresh lead and to provide a rough surface before the wetting out with epoxy. It should be very clean before applying the epoxy. There is an excellent "How To" by Gougeon Brothers/West System that you can access via computer. If you have any questions, let me know. Best, Rognvald
Nov 9, 2008
1,338
I don't get it. I have a shoal keel and I "think" it's fiberglass all around. At least, the part that I walk in (Lancer) has to be fiberglass. Are other keels bolt-on or something?
