Wing Keel Width
bob nutter
Hi: Does anyone know the width dimensions on 1991 Hunter 37.6 Legend? Reason: Boat needs to be hauled for winter. Boat hauler does not use a lift. They use a hydraulic trailer and hauler is concerned over size of fins. Have called Hunter but they do not know. If anyone out there owns a Hunter Legend that is dry docked so an actual measurement can be obtained, would be very greatful to you. Txs.
Dec 3, 2003
2,101
The 1988 Legend 37...
...is around 32". Same problem happened to my friend. But you better check on the 1991 since things may have changed. Do be careful. There was a post on here last fall from a guy who's keel was separated from the boat when the hauler tried to lift it on his trailer and the fins got caught.
