On the C310 transmission, there are two problems. The first is the dampener plate. Catalina spec'd an inferior dampener plate that relies on a plastic ribbon. Mine was completely dust in less than the 600 hours on the engine. There is a better option available that has a spring system instead of the ribbon. I took my motor off the mounts and did other work at the same time but the dampener plate can be changed without removing the engine. Here is
my blog post on the repair. This post also includes a new shaft, new cutlass bearing and new motor mounts.
The second transmission issue seems to be much more limited. A few have failed but others are still running strong. This might be a maintenance issue. It is still very unclear. I change my transmission fluid annually regardless of how low the hours are. I also send samples of the fluid out to be analyzed to see if there is a pattern of wear. After 5 years I haven't found anything.
On the motor mounts, the issue is that the front mounts are actually too low. You can get a good alignment but the set nuts will be near the top of the bolts. This isn't very stable. The fix is to put a spacer under the mounts. This could be done with G10, stainless steel, or even wood if you prep it right with epoxy. I did the stainless steel spacers. Here is
my blog post on it.
Regarding the wing keel comments, the people who complain about sideslip in wing keels most likely don't know how to sail the boat correctly. The C310 is a modern hull design with very good initial stability. As such it has to be sailed more flat footed then the "traditional" hulls like a Cape Dory, Unions, and other long keeled, narrow boats. When you try to sail a boat like this with excessive heal, which is really beyond 20 degrees of heel, you are not getting the appropriate lifting force from the keel. This results in excessive weather helm, side slip and lose of speed. The bottom line is reef early. Here is a
post from my blog on sailing modern hulls. There are some links to some really good articles about this, make sure you read the one on the Morgan Out Island.
Personally I prefer the traditional mainsail with full battens. If I could afford it I would add a track and batten cars. With this setup we can put in the first or the second reef point while moving in less than 2 minutes without leaving the cockpit. I may add a ram's horn so I can secure the reef better for the trades before we cross from the Bahamas to the Caribbean but that is up in the air still.
Another thing that could affect this is rig tuning. I thought I had my rig dialed in but I recently got a professional to look at it. It turns out I don't have enough rake. I have about 2 inches but this rig (again, traditional mainsail) should have about 6 inches. The problem is my backstay turnbuckles are buried. So I need to shorten by back stay and retune. I am trying to get that done along with some other improvements to the rig. Once they are done, the rigger estimates I will gain at least another 5 degrees of pointing ability. I am optimistic.
Please don't hesitate to ask any more questions about the C310. You might want to post over in the C310 section, you might get more answers from C310 owners.
Good luck and fair winds,
Jesse
