E
Ed Carrillo
Hi,I am ready to replace the original port windows with the Lewmar Ocean series and upon removing the first original window I noticed that there are four screws from the inside screwed right into the inner wall. They appear to be holding in place an internal support frame made of plywood that is sandwiched between the inner and outer walls. Before I start cutting the bigger hole for the new windows I have a couple of questions: Is the entire side wall cored like this or just around the windows as it appears? If it just a frame to avoid squeezing the inner and outer walls together upon tightening the window, it seems to me that I need to insert a new frame that fits around the new hole right between the inner and outer wall.I'll appreciate your comments.Thank you all very muchEd
