Rains are coming soon and need to weather proof boat, from the inside it looks like there is a rubber weather strip on window, the other side does not have it and wondering if it is a stock feature and where can I get them?
I assume you're talking about the rubber gasket on the inside of the lewmar ports? If so there are several sources available -a quick google search will point you to the closest source with inventory.
A word of advice buy the stripping in a length. Don't buy the individual rings like I did. The stripping goes in the groove better (doesn't twist) and you can easily cut and glue the ends.
