Window Seals
16
- - Dallas-Ft Worth
I have an 1983 ODay 30 and I replaced the screw on plexiglas windows 2 years ago. My repairman used butyl tape to seal these windows but that didn't work because of the summer heat here in Texas. I can't find find anyone that makes seals for my windows so I am looking for some kind of material that I make my own seals.
Has anyone tried using asphalt roofing felt paper for their boat windows? Did the felt paper work or do you have any other suggestions?
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
From what I learned from Rudy Nickerson of D&R Marine
http://www.drmarine.com/ He claims that the boat manufacturers use Dow Corning 795 Caulking on all plastic hatches and port lights. If you decide to go back to the wood screws and use caulking, I would suggest boring the holes in the lens just a fraction larger than the width of the screws to compensate for temperature changes to prevent the lens from cracking. It may be worth your while to call Rudy and ask him about this. He has a lot of expertise in O'Days having worked for that company. He also has all the parts for them.
Sep 20, 2006
2,955
Hunter 38 Georgian Bay, Ontario, Canada
Robert, I am a roofer :D, the asphalt felt paper is just that .... paper. It's used as a reinforcement to hold the "tar" together for the waterproofing layer. You need a proper caulking to do the job.
Jun 24, 2004
16
- - Dallas-Ft Worth
Joe,
I checked online about DC 795 and it does seem to be the best sealant to use.
Thanks for the information.
Robert
May 3, 2008
4
Oday 272 Stockton Lake
I used the DC 795 from Rudy and DR marine on our 272 SL when replacing one side port(also from Rudy) with great success. I used the original cabin screw holes after filling them with epoxy, I also drilled the plexiglass holes larger than the screw size with a plexiglass drill bit I got from a local supplier. Rudy has great installation instructions available, but be aware that the DC 795 is messy. Dennis
Dec 8, 2006
1,085
Oday 26 Starr, SC
Sealing plexiglass windows - where is Maine Sail?
I am surprised at your comments that butyl tape not working in Texas. It seems to work great in South Carolina. Maybe it is type or brand or maybe it was not butyl tape at all?
Butyl tape forms a gasset after it is exposed to air and heat. As it sets up it becomes like rubber. Maybe the original installation was done incorrectly. Butyl tape is a two step procedure. First is clean surface and install butyl tape and line up device to be seales with holes and tape and screw in enough to hold piece in place, but do not tighen.
Wait 30 minutes for gasket to form, then tighten. Butyl tape in not known to melt in sun after installation. It is used extensively in motor homes, campers and vehicles.
This comment is interesting in that it refutes current job knowledge.
Also there is a one part urethane roofing sealant reputed to work very well for marine use above the waterline, NP-1.
http://www.buildingsystems.basf.com/documents/np1_tdg.PDF
It is not labeled for marine use, but I have used it and it works better than the high dollar brands that say marine. I do not use it below the water line.
Again, the butal tape should have worked if applied correctly. If you re-do project spend extra time cleaning both surfaces and ruff up both surfaces with sand paper to increase mechanical holding power of sealants.
This is a topic for comment by our resident guru and list moderator, Maine Sail.
Ed K
26
