Window seal wont go in!
Sep 24, 2018
4,465
Catalina 30 MKIII Chicago
I pulled the seal on one of my windows in hopes of finding a replacement (there are absolutely no identification marks on the window). So far no luck yet. the bottom of the seal has UV damage so for now I'll flip it over so the UV damaged part is at the top. In order to get the seal back in I have to stretch it a bit. Only problem with stretching is that I end up with "too long of a seal" and then it wont work because of that "issue". What's the secret to getting these seals to fit?
Do you have a photo of the port?
@Dave Groshong at the SBO store helped a friend with a similar problem on his O'Day 28. Dave might be able to help out. Give him a call.
Sep 24, 2018
4,465
Does anyone have any tips for installing the gasket? Lubricant, glue, different technique, etc...
