I am trying to reseal the HUGE fixed window on my Legend 40.5 the "skylight" is made of Lexan and my attempts to fix the leak with 5200 have only resulted in the exact same leak again. I saw in a recent post that 100% silicon was the recommended sealant for lexan but have also heard that silicon has no place on a boat. I personally have found that where others (POs) have used silicon on Gelcoat it does not stick for very long and I have had to go in and fix it with something else. the skylight seems to be expanding and contracting with temperature and that is what caused it to pull away from the 5200. i didn't even think 5200 would let go like that but it has clearly separated from the lexan cleanly.
What is the recommended sealant/adhesive for lexan to gelcoat?
