Tim Haibach
This question is geared mainly toward C27 and C30 owners with the newer style windows without the metal trim. I have a leak and would like to rebed the window. What tools did you use to push the window out without breaking it? Are the 4 screws and the caulk the only things holding the newer style window in place? This leak is starting to cause damage to my port settee and storage locker so I need to fix ASAP. Thanks in advance for any advice you can offer. I did search the archieve already.
