Window install on curved cabin
704
Catalina 30 Sidney B.C.
I just recieved my new windows from Cruising Concepts yesterday and was wondering how other people hold plexiglass windows which are flat to a curved cabin wall as on my Catalina 30 nead to hold for at least 24 hours untill sealant sets up
DJN51
Oct 26, 2009
377
Hunter 23.5 East Chicago In
Rented commercial glass suction cups,applied them on interior side put pipe thru handles and wedged in place.worked great
Jul 8, 2011
704
Awesome idea , I have one of those suction type bathtub handles , I will pick up another one and give it a try ...Thanks
Dec 2, 1999
15,184
You can drill holes to insert screws. This will allow you to keep the material in place until the sealant cures. Once the curing cycle has occured you can remove the screws and fill the holes with a little sealant and you should be done.
We use Dow795 to hold them in place. I believe that Sika also makes a similar product.
Nov 9, 2008
1,338
Structural glazing tape or 3M VHB tape with a structural silicone bead. Holds windows in skyscrapers just fine. The portlights in my boat too.
Oct 29, 2005
2,366
I think you should 1st glue some stand-off on the window edge or plexi so that you won't squeeze out the sealant and it'll form a gasket layer.
MrBee
Dec 30, 2008
425
Irwin 34 Citation Middle River, Md.
Mine were about 36" long. I place them on a block of wood at each end then used hot water and towels to keep the heat on. set a weight in the middle till you get a bend about the same as the curve you need. When it cools down the curve will hold. Then I used a couple of U bolts to clamp a long 2x4 between two stanchions and cut short pieces to go from 2x4 to window. I used one at each end and one in the middle. Once I had all that the right size / length I put the sealant on and let it sit over night. Worked perfectly. I used the dow corning stuff, 795 I think.
Brian
