Windless Operation
Dean Fagan
How do you operate the windless manually in the event the power should fail?
Jim Russell
Winch Handle
Many (most ??) will have a location to allow a winch handle to be used. Not sure if the one on the 376 has this.
Jul 1, 1998
3,062
Use Primary Winch
I don't have a windlass, but, if I did and it failed it would be easy enough to put a snatch block on the toe rail, assuming one has an aluminum toe rail, and run the rode aft to one of the primaries. Since the rode is most likely larger than what the tailer is adjusted for it would have to be tailed manually.
