Windlass Selection for 40.5
John Melton
I would appreciate any advice and/or pictures of electric anchor windlass installation for the 40.5 model. Any information as to brands that give good service etc.
- - Long Beach
Windlass Installed
John, I installed a Maxwell VW1200. The installation was done standard to Hunter's original design intent except at the time (1993) they recommended a Maxwell 800 model. I have an all-chain 5/16" HT rode w/a 55-lb Delta anchor. Since I do a lot of single-handed sailing and am not always able to motor up to the anchor when hauling in, I opted to go to the 1200 model for more hoist power, I would not recommend going smaller than the 1200. Some things to consider on the installation: be sure to run 00 power cables from house batteries to windlass breaker to windlass motor (do not undersize), I mounted the breaker on the port side of the engine compartment at the bottom of the companion way (convenient location to intercept power w/o having to go to main panel), and be sure to order the right size chain wheel to fit your chain. The main problem with the windlass location is that you have to tail the chain when hoisting because it will tend to bunch up. Other than that, no other problems. Good luck
Feb 10, 2004
4,256
Hunter 40.5 Warwick, RI
I installed a Simpson Lawrence (Lewmar)
It was a model Anchorman 1000. It has a 1000w motor and I am in my 7th season with it. I haul a 45# CQR with upto 160' of 5/16" HT chain. At the end of last season (6 years total) the motor quit. I had a local repair shop rebuild it with new brushes, turned the armature, and new bearings for good measure. Cost $125. I really don't think that the motor should have failed in that period of time, but it did. Cost of repair parts from the original motor manufacturer in France (Leroy Somer) were absurd and the lead time was worse. I have nothing else to compare this performance with. Depending upon your particular model 40.5, the Hunter factory may have already installed the "00" cables in the hull grid from the engine compartment to the bow. If they did, that is worth at least $300 in cable. Check before you buy. If you need cable, I have found that Jamestown Distributors in Bristol, RI has the best price and quality. 00-cable (2/0) is a little over $3/ft. You can't use a smaller size because the windlass will draw 100-300 Amps under load. And you must extend the 00 cable to the batteries and switching relay. I have many pictures and details of my installation that I can dig out and email you if you need them. Send me an email through the owner's directory if you want them. Rich
