Windfinder VS Local Knowledge
Feb 19, 2008
508
Catalina 320 Tawas Bay Yacht Club
Hello,
We‘re a little later in the year than we’d hoped moving our boat from its winter home in Bay City, MI to it‘s summer home in Tawas, MI. It seems our schedules and the weather have been at odds.
Our last attempt was last Monday. Forecast called for 15mph wind with gusts to 20; with 1.5-2’ waves. Seems like a great sail, right?
We had trouble with our roller furling and a rigger met us at the dock at 8AM.
”You’re not going to Tawas today are you?” (It was pretty calm when he said that)
He said with the wind out of the NE it is uninterrupted from Canada to Bay City, and he expected much higher wind and waves than the forecast called for. I’m not sure what the wind and waves peaked out at, but by the time we packed up and went home, the wind was steady at 22.
Our next chance to move the boat is this coming Monday, and the forecast looks pretty similar. Both wind and waves a little milder, but direction is E to NE all day.
I would tend to believe local knowledge over Windfinder,
what’s your take?
Thanks,
John
John
Try WINDY.com
Use their “Distance & route plan”function. Choose your start and finish location. Choose the date and time. Set your boat speed. Then watch the wind conditions play out over the route.
Wind patterns over the Great Lakes act more like ocean winds than wind over land. Wind aloft is always stronger than wind at the surface due to less drag. On a long fetch the stronger winds will drop down over the surface and are stronger, which is what you observed. The lakes also develop short steep waves which makes going to weather in stronger winds really uncomfortable.
Use both the general forecast from Windy or PredictWind, taking into account the local conditions, like fetch to make a go/no go decision. Had you been on the eastern shore of Lake Michigan the wind and waves would be much different. A NE wind would be dampened by the shore and waves would not build as high. And remember, long windward legs are challenging and tiring. The motion is not easy and it will be wet with spray.
When local conditions are a factor you can try using the higher resolution models, like the NAM 3km model on WindAlert. 3km means more localized points are modeled than with the broader global models like GFS or ECMWF. The broader models just project winds at farther apart points, and then some algorithm is used to blend the speeds between points. The higher resolution models can actually produce forecasts for specific locations, rather than just averaging between nearby places. In my experience that gives better results for some things like sea breezes or funneled winds. Of course your mileage may still vary depending on the local topography, how well the models match the actual local factors, and how good NAM’s projection of the overall weather patterns are to begin with.
  • Helpful
In addition to using models to predict conditions, NOAA provides some real time data on wind and sea state for the Great Lakes and elsewhere.
On Lake Michigan there are 2 mid lake monitoring buoys that collect sea state data. Unfortunately they do not collect wind data.
Here's one privately maintained buoy on the NOAA site. This is a near shore buoy displaying wind and wave data.
There are many shore based weather stations that can be accessed through the National Data Buoy Center.
In addition to the NOAA buoys there are weather research buoys deployed by private organizations conducting research on the Lakes. These are a little harder to keep track of because of funding.
To build your knowledge of local weather, monitor the buoys watching for trends and the effect of wind on wave height.
One characteristic on the E-W oriented lakes is the lag between a wind shift and a shift in the wave train. On Lake Ontario as the wind backs from N to W following a frontal passage the wave train will build from the NW and continue travel across the lake while a new pattern is building from a more southerly direction. This can lead to really confused seas with steep pyramidal waves as the wave trains collide. There can be some dicey sailing.
