Wind Song is back in Marion for the Summer, after spending the winter at Concordia, and several projects completed by the team there! Most of which are not visible. Just the start and many more projects to go. A few things completed this winter, notable: Holding Tank(deck pump out/ ovb macerator), high capacity electric Bilge Pump, Independent bilge high level alarm, Battery Monitor, new AGM Batteries, Propane sniffer/alarm/auto shut off, potable water hand pump, new brass refer bilge pump out, new sea water strainer, new racor fuel filter housing, engine SW cooling pump rebuild, new main sheet and traveler system at helm, New Wheel (found a nice 32" six spoke SS wheel on ebay, had Scandia in New Bedford machine the hub and Edson wrap the wheel), a large format GPS in the companion way visible from behind helm, some sail work by Sperry in Marion, and a few coats of varnish, waiting for new life rings and MOB pole to go up this summer. Waiting for new sail cover. Anyhow thought you might be interested. Last summer replaced all cushions (sitting and sleeping), oven/stove top, one set of winches, total re-outfit with safety gear and maintenance tools(which have come in handy several times at anchor and hove-to!).
Best Regards,
Lloyd
Best Regards,
Lloyd
