Bungee Helps
Wind Scoops are worth their weight in gold if they are set up right and giving you optimum air flow. The instructions are easy enough. Its the wood dowel that lodges inside the hatch that holds the bottom of the air scoop to the boat. The dowel they provide can be cut shorter if your hatch is small. The key is after attaching the wind scoop to the halyard you want the scoop as upright as possible to catch the wind. So in order to achieve that, you need a length of bungee cord you attach to where the halyard is attached to the wind scoop. Place the other end of the bungee to the forestay or around the furled headsail. This will hold the scoop out but upright. I have a piece of bungee cord (3-feet) dedicated just for our wind scoop. You'll get the picture once you start setting it up.Bob30 Catalina
