Wind generator
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
Hi Maine Sail,
It appears to me that when our wind generator is running we lose or not produce power to the batteries. We've had some very calm days where I noted a general average of power use. Then yesterday with the wind 15-20 most of the day and half the night, we've used more power with no change in our activities or power use. I have the Marine Kinetix wind generator with Spreco 40A/20A hybrid controller.
All U Get
Feb 10, 2004
4,235
Hunter 40.5 Warwick, RI
If you are using a battery monitor to see the level of AH in your bank, maybe the charge from the WG is counting down AH instead of counting up. I think a reversed connection could cause this. I am not saying that the WG is discharging the batteries, but that the battery "gauge" is lying to you. With my Air-X WG and the winds you describe, my battery monitor would show a gain of 50-80 AH over 24 hours.
Oct 2, 2008
3,811
On the controller I rarely see over 10 amps when the wind is gusting over 20. Mostly the amps delivered is 3-7 in about 10-15 knots wind.
All U Get
Rick D
Jun 14, 2008
7,204
All U Get
I may be missing something or misreading, but Rich's daily generated amps sound about right for your AH reading.
Oct 2, 2008
3,811
The watts/wind speed graph in the owners manual shows 200watts at 15 kts wind and 300 watts at 17 kts and then the brake usually kicks on so I never get near the optimum wattage. Problem is that it sometimes causes us to run our gen-set more when the wind is blowing. However last night was different in that the batteries were near full because we had 20 kts of wind until 8 pm and gradually slowing until about 2 am.
All U Get
Oct 2, 2008
3,811
All U Get
Oct 2, 2008
3,811
All U Get
Help Phill, need to get rid of two repeats.
37
Hunter 356 Brightlingsea
What make/model of WG and regulator are you using?
If the WG is in its "brake mode" then the regulator is telling it that the batteries are fully charged.
Most WGs generate in 3 phase, which is then rectified, the rectifiers are usually mounted in the WG housing. The rectifiers provide a one way "diode" effect, so you won't get back feed to the WG.
Neil
Feb 6, 1998
11,760
Hi Maine Sail,
All U Get
Tried to call.. Ring me on my cell, much easier that way...
Aug 27, 2015
58
Cal 2-46 Whitianga. New Zealand
Just a thought. When the batteries a full or nearly the back feed tells the wind gen regulator to reduce its feed.
To show maximum feed from the wind gen the batteries need to be beefing a charge.
We can produce 35amps off our Superwind. But never do as the batteries are almost always full.
Oct 2, 2008
3,811
Since we haven't had enough wind to amount to anything, I'll have to wait until we cross this week to pick up again. It could be that the batteries are almost full most of the time. The solar panel has been keeping the charge up with all the clear days we've been having.
All U Get
