Last year I purchased a Hunter Passage 450 which already had a wind generator installed. It is a Sunforce 600 watt unit. In addition to the control unit it also has a meter installed which shows the amount of voltage going into the batteries when charging. At the time of purchase everything seemed to work fine. At some point later I noticed that the voltage meter was no longer registering, I checked behind the unit and the fuse was blown 40Amp.
I purchased a new fuse and it blew immediately upon insertion. I have not changed anything on the boat that could cause this to happen and sunforce says that it is most likely a wiring problem. Any help is appreciated.
