Releasing the line
I'm not sure if there is one way or another to release a line from a winch. In my experience, both with self-tailing and the traditional variety, what we normally do when tacking/gybing is to: For this exampe, let's pretend we're on a starboard tack and will be tacking to a port tack.1 - Prepare the unused starboard (windward) sheet on it's winch, typically I do this by wrapping the drum and taking up what slack there is in the sheet2 - Release the port (leeward) sheet from either the cleat (traditional winch) or the capture device (self-tailing winch) leave it wrapped around the winch drum and hold the line in your hand. 3 - Begin to tack, (Helm to port/leeward ). As the bow swings over and the sheet needs to come off the leeward winch, rapidly unwrap the sheet and let it run free. Simultaneaoulsy trim the starboard sheet.Note: Though I've listed these as steps 2 & 3 they really are intertwined and depending on the conditions, happen simultaneously - get's interesting sometimes, especially if one or both of the sheets foul on something on deck. 4 - Find your new course/heading5 - Trim the new sheet (starboard) for the new tack6 - Either cleat the sheet or leave it in the self-tailerThe biggest advantage to the self-tailing winches is that they don't need two folks to operate them under load. Hope this wasn't too confusing. I found that though I've done this thousands of times, I still needed to draw a diagram and mentally picture it. I guess we really are in the middle of the winter around here!Geof s/v Day-O
